Command parameters
To update command parameters, use the command unit/update_command_alias:
svc=unit/update_command_alias&params={"itemId":<long>,
				      "id":<long>,
				      "callMode":<text>,
				      "n":<text>,
				      "c":<text>,
				      "l":<text>,
				      "p":<text>}
Parameters
Name Description
itemId unit ID
id command ID
callMode action: create, update, delete
Parameters required only for create and update:
n command name
c type (see below)
l link type (see below)
p parameters
Command types:
  • block_engine - block engine;
  • unblock_engine - unblock engine;
  • custom_msg - custom message;
  • driver_msg - message to driver;
  • download_msgs - download messages;
  • query_pos - query position;
  • query_photo - query snapshot;
  • output_on - activate output;
  • output_off - deactivate output;
  • send_position - send coordinates;
  • set_report_interval - set data transfer interval;
  • upload_cfg - upload configuration;
  • upload_sw - upload firmware.
Link types:
  • empty string - auto;
  • tcp - TCP;
  • udp - UDP;
  • vrt - virtual;
  • gsm - SMS.
Response
On create and edit:
	<long>,		/* command ID */
		"nm":<text>,	/* command name */
		"cn":<text>,	/* command type */
		"lt":<text>,	/* link type */
		"cp":<text>	/* parameters */
On delete:
	null
