Users
Depending on set flags format of response can differ.
This chapter describes flags that can be applied to users and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be united into one JSON.
User flags:
Value Description
0x00000001 base flag
0x00000002 custom properties
0x00000004 billing properties
0x00000008 access level
0x00000010 custom fields
0x00000020 GUID
0x00000040 messages
0x00000100 other properties
0x00000400 phone numbers
0x00001000 notifications
General properties
Flag - 0x00000001
	"nm":<text>,	/* user name */
	"cls":<uint>,	/* superclass ID: "user" */
	"id":<uint>	/* user ID */
Custom properties
Flag - 0x00000002
You can store any user data you need in custom properties. Usually, such settings are user's e-mail, map position after launching etc.
	"prp":{		/* custom properties */
		<text>:<text>,	/* name: value */
	"pup":{		/* private and public properties */
Billing
Flag - 0x00000004
Access level
Flag - 0x00000008
	"acl":{			/* access level */
		<text>:<uint>,	/* item ID: access rights */
Access rights are examined in chapter Get access level.
Custom fields
Flag - 0x00000010
	"flds":{				/* custom fields */
		<text>:{			/* sequence number */
			"id":<uint>,		/* ID */
			"nm":<text>,		/* name */
			"vl":<text>		/* value */
	"flds_max":<long>		/* maximal count of custom fields (-1 - unlimited) */
GUID
Flag - 0x00000020
	"gd":<text>	/* user GUID */
Messages
Flag - 0x00000040
After setting this flag you can receive messages from unit.
Other properties
Flag - 0x00000100
	"fl":<uint>	/* user settings flags */
The list of user settings flags is given in the chapter Set user settings flags.
Phone numbers
Flag - 0x00000400
	"smsp":<text>	/* user phones (comma-separated) */
Notifications
Flag - 0x00001000
	"usnf":{	/* user notifications */
			"t":<uint>,		/* lifetime (sec) */
			"d":<text>,		/* text of notification */
			"h":<text>,		/* subject */
			"s":<text>		/* sender */
